Synapse BOV, Valve Cover, CXRacing IC Core, PG v2 Exhaust Mani, SSP, TT, Gauge Pod
Status
Not open for further replies.
you could possibly make a BOV that added 20hp.. by adding a boost controller type function setting.. but, youd blow your engine pretty quick.. it would just be holding too much boost and our engines cannot take the kind of boost pressure..
hahah 20hp from a bov? I never read about that, but you do gain top end power most of the time (probably no more than a regain from loss around 10hp from what I read). It all depends on the stock bov or bpv you have. You don't need to buy a synapse to gain high end power, any decent bov/bpv would work. The thing about synapse though is supposedly its one of the most responsive bovs in the market.
Well I gotta say that you guys have no clue what you're talking about. The BPV does NOT, WILL NOT, CAN NOT, "add" any power, boost, or anything else for that matter. You can completely REMOVE the BPV, install a plate over the hole and the car will have the SAME power. I've yet to figure out how/why ANYONE with half a clue on turbocharger system function could make this mistake/claim.
The BPV (ANY brand/design) can only HURT performance, it can NOT increase ANY aspect of "performance".
The ONLY "valid" reason for changing out the OEM BPV is that is is physically broken and leaking. My definition of "valid" is for power/performace, NOT for additional or different SOUNDS when it relieves the manifold pressure trapped when the throttle plate snaps closed.
The ONLY reason a turbo setup employs a BPV is to reduce the stress on the turbocharger shaft and thrust bearings from the sudden slowing when the throttle is closed under boost, and the resulting lag as the turbo must "regain" the turbine speed. If the manifold pressure isn't released, it the pressure puts a huge load on the compressor wheel outlet side and slows the turbine drastically. The BPV is installed to allow this trapped pressure to vent back into the main air inlet to keep it "in" the system. In older systems not using MAF sensors for misture control, a BOV can be used to vent the pressure overboard.
The OEM BPV reacts faster than ANY aftermarket BPV, so the ONLY result you can possibly get from replacing a properly functioning OEM BPV is more noise and LESS performance.
Now granted, I did chime in a bit on the subject matter, but still fail to see how this has anything to do with my FS thread. Although I do appreciate the bumps, could I please ask you gentlemen to start a thread about this on the Mazdaspeed 6 : Forced Induction part of the forums? Here you all go, I will even provide the link to it. . . http://www.mazdas247.com/forum/forumdisplay.php?242-6-MS6-Forced-Induction
Bump for updated pricing. Prices are shipped unless otherwise stated.
Synapse BOV - $150
MS3 Short Shift Plate with Shifter Weight - SOLD
GReddy Full Auto Turbo Timer - SOLD
GlowShift Center Dash Triple Gauge Pod - $35
CX Racing FMIC Kit w/ BOV - $485 + shipping
Status
