madvillian
- Mazdaspeed3
i thought with the RR mani/DP combo you could only recirc it into the DP? or am i wrong? or are you on a custom DP?
BTW. in the photos i noticed the mani and turbo look really close to the firewall. you running any upgraded mounts? i was running just a RMM and my motor moved a s*** ton, i know socks with his set up was having problems with his mani smackin the firewall which is what apparently caused his head to lift. i dunno how true that is but your setups bigger than the 3071 im on now and i have plenty of room but im gonna be on full upgraded mounts to be safe.
Well RR has an option now, you can get a dp with a tube in it for the WG or you can get one without. my downpipe had a tube in it on their setup but scott cut it off and capped it off for me. He actually did a ******* awesome job.
I am running the full SU mount set. Socks head lift issue was not because of the firewall, there is just no way. His head lift issue was caused by 433whp and whatever ungodly amount of torque he had haha. It was the nitrous man. That s*** kicked in fast and hard and killed that motor.
