turbines are much harder to size, because theres no clear cut relationship between A/R and shaft rotational speed (from what ive read). you cant just say "if your engine needs ___ lb/m of boost to maintain ____ psi, the rotational speed with ___ compressor means the shaft goes ____ RPM and you need ____ A/R on the turbine".
so much comes into play with VE and airspeed velocity its impossible to calculate empiracally. things that happen in the manifold have a big impact on the A/R... from what ive read, everything says you can only ballpark A/R or go on experience. things like the backpressure created by the bearing resistance versus the forward flow out of the head/manifold... its just two forces working totally opposite one another
