Your wishlists: Top 3 performance items
Well I thought this was a wish list for the 2011 CX-9.
I may do a new thread about it, or maybe not. Someone else can do it.
I`ll say this, in my wish list is the 3.7L V6 with 305hp of the mustang.
That would be a reason for the car to be smiling all the time LOL
A DI version engine with give you 10% bump in torque/power with even better MPG.
I bet it is coming to the next remodel of CX9.
DI is "IN" now. Even the new Hyundai Sonata has DI engine, forcing new Honda Civic to be delayed for 1 year...
When you bump up power with forced induction, you need to check if the transmission can handle it with reliability to go with it.
I test drove the Ford Flex with and without the 3.5L ecoboost. The difference were day and night. The Ecoboost really put some Zoom-Zoom in that car, while keeping the MPG the same. And it was in AWD configuration to handle all that power, so in reality it would actually increase the MPG a bit if its available in FWD.
On the flex the ecoboost verion were DI and Twin Turbocharged. That's why I am so suprise it was able to return the same Mpg and an addition of nearly 100hp, compare to the standard 3.5L
The oddity is that trailers are for the most part only available in less than 3500, 3500 and 7000 lb increments due to axle ratings. That means that it is not worth even towing a standard medium duty 3500lb rated trailer such as a Uhaul 5x8.
As passengers, unloaded trailer weight and anything in the vehicle need to be included in the tow capacity rating, adding a 200lb driver plus 350lbs of passengers (one big ass wife or a slimmer hipped model with a couple of school age kids) plus 100lbs of luggage and a 1000lb empty weight trailer (unloaded 5x8 Uhaul utility for example) leaves you with less than one ton of trailer cargo (200+350+100+1000=1650 subtracted from 3500=1850lbs net towed capacity. Not much at all and almost not even worth towing a 5x8 utility trailer. That puts you down into the small Uhaul or even Harbor Freight fold up type trailers that can be pulled by a compact SUV with a 4 cylinder engine. Puny.
I just don't believe the CX9 is that wimpy even without a more robust transmission cooler. The Aussie CX9 is rated higher than the US model presumably just because of different hitch and I recall the version down under is rated to tow somewhere around 4000-4500lbs. If so then it is not a transmission issue at all but just a marketing decision (bad one) to not offer a Class 3 hitch and 5000lb rating. I smell a zoom zoom marketing call rather than a carefully calculated engineering decision on this.
I believe there is a difference between payload (passenger + luggage, dead bodies, etc) and towing capacity. Techically, you should be able to carry you payload capacity and your towing capacity, which is pretty impressive.
I always thought that too but there are a couple of statements on the Mazda that suggest they consider payload as part of the total. Regardless it is still odd that the CX9 is rated closer to a Subaru Outback in towing than to the Pilot, MDX, ML, etc etc. 3500lbs towing capacity is just wimpy for a 4500lb 270hp vehicle.
Aussie hitches are different, so maybe that's it. To go to a US Class III (5000lb) receiver would mean people who don't follow rules or instructions would try towing 5000lbs, instead of the 4500lb limit.
With so many morons filing ridiculous lawsuits against big companies for their own stupidity, I can't really blame them for being cautious. You can spill coffee on your own lap trying to drink it while driving and get millions from McDonalds, so why not sue Mazda because a Class III receiver should be able to tow 5000lbs, not the 4500lb limit of the car?
This question continues to go in circles when it has already been answered...
No, your CX-9 cannot tow 4500-5000lbs because of legalities not because of a punny transmission and engine, accept it and let it go whoever has an issue with it. If you want to tow that weight go buy yourself an MDX, ML or what not. Besides this thread was not labeled "Why cant my CX-9 tow 4500-5000lbs?" it is called "Your wishlists: Top 3 performance items"
OK, Top 3:
1) Better MPG with either diesel or DI engine producing roughly the same HP/torque
2) Better Nav/sync like electonics
3) 5000lb tow capacity
Does that make you feel better?
