How many pounds of boost is everyone running?
turbolife/injen/j-pipe back/ss afc. still at 6psi. 7 in winter (no boost controller, stock wga)
soo sig for mods on stock tune and 8 psi for now, forged motor and gt3071r turbo coming soon.
currently very close to stock, at stock boost (5.5psi) but thatll change soon...
T3/T4 50 trim in the mail, FMIC, 2.5" downpipe and electric cutout... probably will run 5.5psi with that as well.
and to the OP: i would stick with 8psi until you do a midpipe and get a tune.
Vibrant exhaust, front and rear MM, K&N drop in filter and a forge wga set for 10psi.
160xxx miles stock.........alll stock........til I return from deployment
then it will be on!
I have 60 mm corksport, smic upgrade and hardpipes, greddy knock off bov, and forge bpv, pcv is gutted, and I have krank vents installed, car randomly runs anywhere from 5 to 6.5 lbs. I need to figure a couple of things out on it, but my gas mileage is up over 33 now, I still need to build the mil eliminator using the spark plug antifoulers (the 02 sensor bung is before the high flow cat on this exhaust, weird)
Thad.
really why duch low boost?
its capable of moving more CFM at redline. i recently learned me some good knowledge: the size of the snail doesnt matter until you outflow it at higher RPM, and the GT2554RS is a joke of a turbo... a 2.0L w/ 4 valves per cylinder outflows it at 5500 RPM or so. the disco potato is just warming up.
i have a joep mbc laying around here somewhere. i wanna turn up the boost but im scared. lol
