Outlawstar98
 - 2003 MazdaSpeed Protege / 2013 BRZ
Hm... Are you useing a deticated vac line to the booster line? It helps alot.
			For the break booster? Just but a vac block. I hve a MAM Vac block sitting around if you want to buy it, it has room for 3 ports I think. Which advance auto should have the ports that screw right in. You just gotta make sure you cut the booster line at the right section.
The temp sensor gets pluged back into the intake, if the hole is gone because you had to remove a pipe for some reason, just drill a new one.
And Tzar, I dont understand your question.
you could probably just buy a check valve...
well, the positive pressure wont be an issue, thats for sure. i dont think any check valves exist that are rated below 100-150psi... we are obviously nowhere close to that. theres a bunch of different barbed check valves available on mcmaster e.g., but most of them arent flow rated... for flow ratings you have to get ones with various tube ends.You could def use a generic check valve, however, considering the fact that your brakes operate as they do because of proper vacuum on the brake booster, you'd need to ensure that your new generic check valve allows enough vacuum to pass through it, or your brakes will be hard or non existent. Also, the check valve needs to be able to handle whatever PSI you're running, because the brake booster is not meant to see excessive, or any positive pressure for that matter.
I'd rather use OEM part hahah.
