What blowoff valve are you running?
Anyone who wants to upgrade their BPV to anything else should first realize that you NEED to have ~ a inch sized one to be most proficient in getting rid of the "compression surge" just replaceing the stock one with the same size nipple is complete failure. It willnot help. But with a greater nipple it releaces the pressure much better.
Just a reminder.
this is true, I have a 1" nipple from my hot pipe to the stock BPV. This was actually accidental that because I have what can be considered to be the first generation SLS Hot-pipe which has a 1" nipple on it. I think SLS changed the nipple back to 3/4" after some members complained about having a hard time fitting tubes on it.
He had all the washers installed? which would cause a stalling issue... not "make the car slower" issue. Its a mindfuck.... haha Im at stock boost with 0 Washers in my TurboXS....
idk why it mae it slower. I tried all washers, less washers no washers even lighter washers that didnt come with the valve, my car just didnt like it. I don't know what to tell you. I sold it to sandspeed, seemed to work for him apparently.
Never had a problem with any greddy valve though.
every BOV will cause stalling issues if you are venting all the boost w/o relocating the MAF. MAF is not designed to be under boost (that is one reason not to relocate it) and venting boost to the atmosphere is a waste of boost (dump it back into intake)
well this has been a super informative thread. and it has simplified things for me and prob a lot of other members. so relocate the maf to the cold side and put the bov on the hot side and we should be all set??
well my car doesn't stall all the time. And I've mastered the art of tapping the gas pedal before it get's a chance to stall anyway. So it's not a problem.
Not a fan of relocating the Maf sensor. Never will do it.
It WILL cause a rich condition between shifts or letting off hard, but doesn't have to cause stalling... Blow through MAFs have been used for literally over a decade with no associated issues. Even professional tuning shops featured in Magazines, are using blow through MAFs. You're right though, they were not designed to take boost.
Recirculating has it's values, but to those running a gt2554r or any other small turbo, we don't need that little bit of air to help us spool, as we already have a annoyingly fast spool time that falls on it's face @ 5500 rpms and up.
And the argument of BPV vs BOV will always be there. So just a FYI try not toget into "bpv is better because..." stuff, it's all in theory, never saw it proved. That can go eaither way.
But to run a BOV you need to relocate your MAF, if you don't it's stupid not to because the callig issue will always be there and you can't upgrade boost easily. Only worth it not to if you have a standalone.... Because then you control everything.
ive always been told, unless your runing ~20psi then BOV's are usless and only for the sound.
the BPV was the smartest thing mazda did with our cars IMO
Completely agree, BPV is the only thing they did right in my opinion.
Agree w/the 20psi also, which would be crazy to do in the MSP
Naa I don't agree, but this ISNOT the thread to talk about this. It's already been talked about.
