I have a Protege 5 2003
My cruise control stopped working (I played with the fuses but they are all fine.. maybe not properly inserted.. but which one? cuz there is no indication)
I read around the forums and people are saying there is an on/off switch? Where? :S
Thanks
Pushing the main button on does not light up the cruise light on the dash. The cruise light on the dash does not come on until you try to set it with the set button.i have the same problem. My main does not turn it on or off. Any other options to this fix?
+2 on that, IIRC there was a thread back awhile where a bulb or fuse out was making some seemingly unrelated stuff go on like this.This may sound weird, but check to make sure you don't have a tail light out. I don't know about our cars, but in some vehicles, an improperly functioning tail light will disable cruise control. Essentially, the car sees it as a "break" in the system and disables the cruise control as a safety precaution.
Make sure you're going over 35MPH, don't have the clutch pressed in, or have the brake pedal depressed.
My cruise still turns on at 25mph when I was testing it a while back.
Just assumed. For us it wont come on below 50 KPH.
There have also been problems reported with cruise modules going bad. I rarely use mine except to check if it is still operational. Sometimes I have to turn off the main switch then turn it back on and try to set it again. Sometimes it takes 2 or 3 times of that before it will actually take over and work like it should.
