Laser Blue
- '03.5 Mazdaspeed Protege / Laser Blue Mica
don't get a blow off valve get a BPV i'll attach a pic, but instead of venting to the atmosphere you dump it back into the intake right before the turbo.
who ever you bought lied to you, they went through some extensive work to put that set up on.
These pics are perfect! They show exactly what needs to be done to mount the BPV... the only thing I might do different would be to buy silicone tubes with elbows to eliminate the fittings which would open the i.d. of the hose a little more and shorten it up. Shorter is better.
Edit: While you're waiting for the new parts, you could pass the time by checking all your vac line connections to eliminate vac leaks, and check and tighten the clamps on all your pipe couplers.
