Ricktalife
- 2012 Subaru WRX
That s*** looks sweet. I like how you even substituted the black for blue on the valve cover where I'm guessing the lines for the injectors go. Lol I don't know what everything under the hood is but I'm trying.
i guess we should start lining up for rides. haha. you guys are using split second to tune right? taking it somewhere to tune it? or damian are you tuning it yourself?
well.. good news tonight i guess...from ghost ones car-2731
i got everything put back together. i started the car.. it started! and ran.. bad though.
at first the idle was holding/pushing up from 2k to about 3500.. then when i readjusted some things and tried again, it was very quickly, going from 2000-2500/3000 rpms up down up down up down. i'm not sure why this is..
things considered as possible issues:
-not having a 440/28rs/fmic/walbro map installed(so running on the superstock map
-possible vac leak, although i didn't really hear anything
-IAC valve dead
any thoughts??
also zach, the coupler/reducer that was 3" to 2" was incorrect. it's actually 3" to 2.25".. go figure.. so that one particular has to be sent back.
Well I've got 25k so![]()
-IAC valve dead
any thoughts??
With everything going on...like Kooldino said. I'd like to add....put the stock injectors in...it'll be worth it. Once the car feels solid then put the 440's and learn how to tune with AFC. Actually I would learn to tune at lower boost/stock injectors...then move to the next level. Too many mods at once...where the hell do you look first.
