When you re-flash the ecu with an new /updated map does that reset the historical fuel trims?
Reflash erases all LTFT, like Blender said.
Well I downloaded the new v104 stage 2+ 93 octance map tonight. Adjusted the MAF tables. Smoothed out the throttle response and APP translations. Adjusted WGDC so I won't be boosting under 3 grand. Also lowered all the load tables for each gear under 3 grand to compliment this change. Changed the closed loop exit delay tables. Smoothed out the boost response and have it set to max at 19psi and tapering down to 17 by redline. Increase my idle to 1000rpm so it does away with some of the vibes. Giving her a test drive tomorrow to see how she does.
Sounds good brother. I'll prob use the same base map next week... stage 2 tihsf +fmic, no? Is it on bova's site?
I did away with my race roots map. Not only have they not sent me a revision in one week. The map all of a sudden started back firing on wot shifts when not using flat foot shifting....
Hmmm... didn't some idiot help sway you to dump those guys because they are grossly incompetent? lol I'm glad you're into ATR and self-tuning. You map tweaks sound good, keep us posted.
What map are you running? I have the same issue with random KR at partial throttle running the Stage 1 maps...After doing some reading, it seems like the random knock at partial throttle is the norm for the Stage 1 maps....
I'm not sure if it is timing or what, but the stage 1 and stock maps suck. I bought an AP last year before I was stage 2 'ready' and had all that crap and returned it after 3 days. I'm glad I did... now that I'm on stage 2, hardly any KR at all. I was just thinking that perhaps since timing is more advanced on stage 2 maps than stage 1 maps, the ECU has more timing it can "pull" under WOT than on Stage 1 maps. I know it dumps fuel too, but I would think KR would be removed quicker through retarding timing over dumping fuel. I'd have to compare stage 1 to stage 2 maps at minimum, but I just thought I'd mention that.
Got some crucial KR on the way home from work today. I was in third gear and gave it some gas in low RPM. Never seen knock like this before. The car definitely stuttered for a second before I let off the gas. Any ideas?
Dude, that log looks dangerous. You start going into boost at 2,200 rpms, and you're at 12 PSI at 2,500rpms with KR of 7. That's not cool... your calling on a lot of load at low rpms with skinny rods and having a lot of detonation imho. Too bad you didn't log timing and the other pids Forzda mentioned... I don't know why your car didn't pull more timing (and not sure how much... maybe it pulled as much as it could). It don't see your AFR's plummeting either. If you weren't under WOT it's harder to decipher things, though judging by your TP% it looks like you either were, or were pretty close to WOT. It sounds like you probably need some work on your map, and reduce load and lower rpms like Qwik6 did. It depends on how those maps are set up, I have no idea about stage 1 maps. Even doing this won't solve all your problems... you gotta stay out of boost in low rpms and you downshift more,
especially on the highway, because if you're in 6th gear going 55mph and touch the throttle you're going into boost. Give it 1/2 throttle at your at 10+ PSI.. at low rpms.
Does anyone know if calibrating the MAF with ATR will help with this?
IMHO, I think that a great calibration of the MAF is key to having a solid map. Even if they're within 7, you want them to transition smoothly across the MAF volts (I do at least). Also, if you get them really solid (within 3 say) and are tweaking other things with the same mods and but changing air flow, the fuel trims should remain the same. I only break in the map for like 5 miles, which is still unnecessary imo, but if you don't your trims will be off due to 'tip in enrichment.' If the MAF is calibrated perfect though, those fuel trims should go back to near 3. YES, this may be excessive and within +/-8 is fine, I just don't like them that far off.
