lol, I had that same code come on a few days ago, reset the ecu and it hasn't come on yet, but the idling has been bad so far, also do you have a wideband? I didn't see one in your sig. but under WOT it's very possible that it's fuel cut because since the temp. dropped after this week, it's been hitting fuel cut which is stumbling unless you can get it to full boost before fuel cut than the engine just jerks, but I noticed that if it just hits fuel cut right off the bat, the engine just kinda fumbles and stuff, and the wideband shows 10 afr which is it's min. reading, im sure it's richer than that.. I just haven't had time to tune the car, and when I was about to, the CEL came on for the first time.. but ya, code hasn't come on yet again, but it was stumbling in idle before. I'm going to clean the MAF tomorrow and maybe the EGR sensor.. I had an exhaust mani leak from the side before but I could hear that and I fixed it (the bolts were just loose) so gotta figure it out.. I'm not sure what would make the fuel pump go bad all of a sudden, I had stabil in there when I stored it for the winter, I'm thinking about putting some seafoam in the gas and PCV valve to clean it out after sitting for the winter, I did it last summer but couldn't hurt to do it again...
would be nice if someone could figure this out, and it was a similar issue for all of us, I don't feel like having a long drawn out problem that I have to deal with.. I just want it to be something semi simple for once lol
EDIT: lol damn, 2 posts before I finished mine lol, oh also I had the car under full boost at 4th gear for a 30sec, story and other details here
http://www.msprotege.com/forum/showthread.php?t=123771575&page=3
but I notice the bad idling, I know under WOT when it's this cold now (45-60) it's just fuel cut
