yes they are. will be picking up my dnp mani today and dropping off my VC to get powdercoated white.
you gotta paint your intake manifold if you are going white cause that thing looks dirty compared to it haha. what fmic do you have?
ohh nice!!! i couldnt be more happier with the work theyve done for me so far.. will be bringing my calipers to them as well..
i agree with bova.. your going to have to keep ur engine bay super clean after thats powdercoated.. that white will make even the slightest thing thats dirty look Reallyyyy dirty lol..
lol. im ready for that.. i was thinking of painting the pipes white with black hoses, but i think it will overkill(ricer).
No, it's the same as any other 215/45/18. Those are industry standards.
actually this 215(goodyear) is Much wider than the stock 215?? i showed this to Chris(batou) in person just to make sure i wasnt crazy.. and I asked our local tire guy and he says its not the same with every Mfgr?? the good years have the same numbers.. but are physically much different tires.. no idea how thats supposed to work.. but, when i asked the Goodyear guy about the 225-235 size? he laughed and said theyd be way too wide and rub the fenders really hard!!
Section Width
Following the letter(s) that identify the type of vehicle and/or type of service for which the tire was designed, the three-digit numeric portion identifies the tire's "Section Width" (cross section) in millimeters.
P225/50R16 91SSidewall Aspect Ratio
The 225 indicates this tire is 225 millimeters across from the widest point of its outer sidewall to the widest point of its inner sidewall when mounted and measured on a specified width wheel. This measurement is also referred to as the tire's section width. Because many people think of measurements in inches, the 225mm can be converted to inches by dividing the section width in millimeters by 25.4 (the number of millimeters per inch).
225mm / 25.4 = 8.86"
Typically following the three digits identifying the tire's Section Width in millimeters is a two-digit number that identifies the tire's profile or aspect ratio.
P225/50R16 91S
The 50 indicates that this tire size's sidewall height (from rim to tread) is 50% of its section width. The measurement is the tire's section height, and also referred to as the tire's series, profile or aspect ratio. The higher the number, the taller the sidewall; the lower the number, the lower the sidewall. We know that this tire size's section width is 225mm and that its section height is 50% of 225mm. By converting the 225mm to inches (225 / 25.4 = 8.86") and multiplying it by 50% (.50) we confirm that this tire size results in a tire section height of 4.43". If this tire were a P225/70R16 size, our calculation would confirm that the size would result in a section height of 6.20", approximately a 1.8-inch taller sidewall.
Seriously, Im not trying to start an argument on this.. thats why I made Chris check for me? i appreciate your info.. but, 215.. isnt always 215..
I took a shot that helps a little.. thats a 1/2" overhang on 215 tire.. on my bridgestone it was flush to the rim.. and thats how i got my curbrash.. the goodyears wont let that happen so easily..
215/45/18 (stock) tire diameter : 651mm
225/40/18 tire diameter : 637mm (14mm shorter than stock)
225/45/18 tire diameter : 659mm (8mm taller than stock)
215/45/18 sidewall height : 97mm
225/40/18 sidewall height : 90mm (7mm shorter than stock)
225/45/18 sidewall height : 101mm (4mm taller than stock)
215/45/18 revs/mile : 787.3
225/40/18 revs/mile : 804.6 (17.3 more than stock)(2.19% change)
225/45/18 revs/mile : 777.7 (9.6 fewer than stock)(1.21% change)
well like i said.. these tires are much bigger! not just the lip part.. and boosted.. youve provided no input here whatsoever.. just slagging and tude..
and seriously ive seen plenty of ASE mechanics screw s*** up.. so that means nothing to me.. look at how many nightmare dealer posts are here?? All ASE certified!! and if you wanna do business with the public? you should watch your posts.. someone might be reading this and decide your just too hard to work with??
and ive asked several techs about this.. and several have given me the same answers.. the specs are not exact.. just like the treadwear?? if i had two tires to put side by side I would..
