depending on if I can get my car inspected by the engine shop and get aligned after work, I might be trying those 17x9 +35 tonight...
After having an extremly stressful day, I went out for a nice drive tonight. It sure did help me forget my troubles, however, right before I got home half the street went dark. Figured a bulb went out. Got home and looked, damn shroud came off again and was blocking the light. Looked at the other shroud and its about half way off, must be from the vibrations.
Anyways, I get to take both my lights apart, yay! :|
Got my driver side torn apart and put back together yesterday, then today I tore apart the passenger side, re-aligned the projector, and put it back together. I won't be reinstalling them until I get home from work tomorrow, to give them the most time to dry before they face the vibrations of the motor mounts Thursday morning. I also will most likely be picking up my JDP lip and testing the 17x9 +35 Thursday night
My led city lights also came in and after testing them with the different lights, I actually like them with no lights, parking lights and kinda the highs but I don't like them with low beams. Is there a simple way I can wire them to turn off with the projector?
yes, what I would do is power them off of the ignition (or your own switch, or the running lights, etc.... whatever you want to turn them on) take that power lead and power a relay with it... have it set up on the normally closed side of the relay. then, wire from your headlight wiring to the switch side of the relay, and ground the other side. so when you turn on the headlights, it will open the relay and turn off the city lights.Got my driver side torn apart and put back together yesterday, then today I tore apart the passenger side, re-aligned the projector, and put it back together. I won't be reinstalling them until I get home from work tomorrow, to give them the most time to dry before they face the vibrations of the motor mounts Thursday morning. I also will most likely be picking up my JDP lip and testing the 17x9 +35 Thursday night
