I posted some pics of my install in another post, but I figured I would do a more detailed install log of the whole install. Sorry there are some detailed steps missing, but I never intended to do a step by step when I was taking pics. Hopefully someone can get something from the photos and whats involved.
Empty shell
RAMM Matt is place
Door skin off (one of the nice things about the Mazda 3)
Layer of Matt on inner door
Layer of ensolite (I think thats how its spelled)
Modified door skin to accommodate the 8" Dynaudio mid-bass
Ensolite on the outer door skin
Laid the wooden rings on the factory kick panels
Wrapped with stretchable t-shirt material from local fabric store
Panels drying with first coat of resin (installed 2 layers of woven matt after this step)
Test fitting Dynaudio 3" midrange in panel
Dynaudio 8" mid-bass in door
Made a mold of tire well using fleece material from local fabric store. I laid the fleece in the tire well, then laid the wooden built frame on the fleece and the round wood disc at the bottom of the tire well. I then stretched the material tight and stapled it to the wooden frame. Once all tight I began to soak the fleece with the resin.
Tada!! Once dried I removed the mold from the tire well and installed 5 more layers of fiberglass matt.
I built a rectangle top for the box and cut out a rectangle shape in the top. I then cut the woofer ring. I layed the cloth material down on my work bench. I laid the woofer ring on the fabric and shot it to the table with a nail gun. I elevated the box top above the woofer ring with dowel rods and stretched the fabric tight between the two to create the shape.
Once dried, I unfastened the parts from the table and here is what I have
Test fit of the JL12W6
Some high build primer and a lot of sanding
Here you can see how it will sit in the box. The curve portion of the box will get covered with 3/4 mdf and become the amp
rack.
Painted red and installed in the car
Here you can see how the amps sit on the amp rack. I forgot to take pics of the bit one and the 3rd JL amp that sit below these two amps.
Finished passenger kick installed
Drivers kick
Finished amp rack. Wrong color silver. It will be pulled and repainted with automotive paint to match the factory wheels.
Some night pics
Shane
Empty shell
RAMM Matt is place
rack.
Drivers kick
Some night pics
Shane
