Aftermarket partout 2002 Protege
Status
Not open for further replies.
thanks again tfmms Worked a double today and tom Trying to pick up shifts to help out the down payment.. glad to here your item got there quickly. get back to me to let me know how it feels
It was on a sedan, theres NO difference what so ever though... did you run into any problems?
it just looks like really small piping 2 1/4 inches.... going to install in the morning, are all the injen's that small in diameter?
I don't know if they're all that small but I do know its a real injen and it will fit your P5.
hmm... no word on the header.... tried textin ya... but no luck.. called too went to voice mail... any word?
It should be.
There isn't a place for the second o2 in the header so why would there be a non-fouler? Anyways, its like $2 in parts at NAPA to make one. You'll need a bung welded into the midpipe, thought we already talked about this? :/
BTW, Jerry... your o2 you posted up with your non-fouler attachment is done wrong. Fatti and I noticed it when we took it off the car, you do know you were suposed to use both non-foulers right? The first one has to get drilled through and the second screwed onto the end, you only had the one dilled through... which makes it useless.
there should be a second spot... maybe i didnt look at the pictures right, but with factory there is one at the TOP of the manifold and one on the j pipe... none on the mid pipe.
either way... ill make one.. no worries
Status
