Wagonbacker9
- 2004 'Hoe
you sure your clutch isn't gone? theres no way you're spinning in 4th on dry pavement.
I wonder how much they are from the stealership?
posting this without a link is just mean.onlinemazdaparts has them for $7 each plus shipping
that was the missing piece... thank you! loltheyre not too hard to find, onlinemazdaparts.com, search for the 2003 tribute and find the washer nozzles
get: NGK ZFR6F-11 platniums
sadly, I've bought them once, but I've recommended them so many times I have the model number memorized.
How come you didnt bring the motor and the tranny out together?
Put in GlowShift A/F gauge, boost gauge, and voltmeter... But, while replacing all the vacuum lines the nipple broke off my BPV :'( Was planning on replacing it when I put in hard pipes it just might be sooner than later.
I have a Forge WGA to replace also but right now feeling low. (bang)
Problem is that thanks to my big mouth and complaining to Mazda Canada about the local stealership I am going to have to look elsewhere for parts or get the wife to order them for me!
i went to mazda today and was looking to get some factory exhaust gaskets to cut the inside out of for my apexi n1. they are like $9.50 a piece! and i need 4! rock auto here i come!
but while i was there i asked about a exhaust manni. mine is cracked but i will try and get a steedspeed or thunder manni. but anyways long story short, the factory manni is still $1780!!!!
1 question, 1 point.
Question: Can you run the car without a BPV (n00b question I know) and what's the dangers? (by no BPV I mean, plugging the hole up or running it open) I'll explain why I ask when I'm answered (no I am not currently running this setup).
