I have searched all over the forum, but i only found unclear instructions. So i decided to do a write up.
what you will need:
wire cutters
electric tape
wire
male and female connectors
step1:
remove negative battery terminal.
step2:
take off the side panel located on the driver side dash. its just 5 clips holding it together.
step3:
locate your fog light relay underneath the driver side dash. It is a black relay with white clip. it should have some numbers on the black clip
step4:
cut the red wire going into the relay and connect the new wire into the wire going into the relay.
step5:
The other end of the red wire just tape it up(no short circuit so you will be fine)
step:6
unplug your fog switch and locate your light green/black wire.
step7:
tap your wire thats coming from the foglight relay into your fog light switch. tap it to the light green black wire.
step8:
put on your battery terminal.
step9:
check for results.
step 10:
if everything is okay, then put your pannel back and you're done. (thumb)
what you will need:
wire cutters
electric tape
wire
step1:
step2:
step3:
step4:
step5:
step:6
step7:
step8:
step9:
check for results.
step 10:
