Hey matt V what kind of bulbs should i get for my p5 looko at the post i posted above thanks.
and are the 3k fogs the yellow ones? or should i go more to the 10k hid fog lights what do you thinki just want them bright as hell,
and are you wanting Dg grill or selling one according to you avater?
I cut my wiring here and reconnected it in the fog light housing, kept the dust cover outside of the fog light housing, kept the stock wiring outside of the fog light housing too.
Thanks, this makes sense.
Has anyone had an issue with any of there lights not turning on? I've had to toggle the headlights off then back on to engage my front passenger light. It's happened a couple times. When I was testing the bulb/ballast it happened and seemed to only happend on the front passenger side. I swapped the bulbs/ballast so it doesn't seem to be the kit itself.
you're likely not getting enough power to fire the igniters off... this is why people use a battery-direct harness... Doing this is drastically shortening the life of your bulbs, and likely your ballasts.
