my god, i thought when i made my entire setup i was tight for space....... that stuff is crammed in there!
Haha yahhh it's a tight fit! Especially since the turbos mount where they mount, but it looks badasss though!
is the scavenger pump to take the oil from the drain side of turbos and push it back into pan since your turbos are so low?
Yupppp exactly. That way the oil won't get backed up in there and blow the seals/have it coming out the tail pipes haha
that's got me thinking......... wonder if i could just use a separate oil system with a tank and a cooler and a pump like yours then i could also have the oil circulate after the car is off to cool the turbo down.
Never understood the point of a TT to cool off a turbo. You still have hot ass exhaust going through it
I guess you could do that...the thing is though...you want the turbo to be hotter when you are out driving it, that's what helps it spool faster....that is the main reasons turbo blankets were invented...not only to help so the heat doesn't soak your engine...but to keep the heat in the turbo and help it spool sooner.
And be his personal trunk monkey?(rockon)can I ride in your trunk?
Dammit man...the build looks great.
Anxious for this 9 second car to get done! Hope your taking vids when she comes to life. I'm following this closely...keep it up man!
