I finally got around to installing my unit, but am having a few problems:
1) When using Finean, other than telling me the maps are unregistered, it also says it cannot locate the GPS port. I've tried placing the GPS antenna on the dash facing the window as well as under the vents behind the headunit. When I went to Finean's config page and clicked on 'auto' under GPS ports, it just cycles through with no result.
2) Route 66 tells me its out of memory.
3) When playing mp3s off a CD/DVD, is there anyway to browse the folders? I only see the option to change tracks, even shuffled is greyed out.
4) I know some people have placed the microphone behind the steering wheel, but where did you have the cable come out of?
5) Does the bottom edge of the unit sit flush with the temperature controls for you guys? Mine doesn't seem to want to.
Thanks!
1. i deleted Finean off my sd card.
2. route66 gave me 0 problems.
3. i haven't tried playing mp3's off a dvd or cd. i'd try the usb port.
4. i ran the cable under the driver side dashboard and clipped the mic to the the temp slots right next to where you put the key in the ignition.
5. mine isn't flush either.
does your AM stations work?
