Nice build. Sometimes I wish I had a blue MSP, but mine has treated me very well for the 53000 miles I've put on it.
What's with the hood gap in the front of the car?
Ah, that's what I get for being lazy and only looking at the pictures
Unfortunately my CEL came back on during my drive home from work so I'm going to go get it scanned.
lame.
Thank you, what color do you have?
dude, what's up with the bad plug wires?
hope that crapdanza flywheel got balanced with the rest of the bottom end too
Silver. At least it doesn't show any dirt.
well then your machine shop is no good because every good engine builder knows that something with lots of rotating mass (flywheel) needs balancing with any sort of bottom end balancing! it won't be your fault for not knowing but it'll be their fault for not reminding youI didn't know the stock wires were insufficient but since I got this cylinder # 3 misfire code going on and read that it might be the spark plug wires and/or boots I'm going to get new ones. Do you have any suggestions as to which are not bad? And again I was unaware the flywheel needed to be balanced, can you tell me more regarding this?
didn't I say already the stock wires are s***?
they break easily, are way too small, and have too much resistance in a high power engine
just get NGK wires and be done with it... cheaper and BETTER
the good shops I deal with ALWAYS ask for the flywheel AND pressure plate be brought in for balancing with the whole bottom end
furthermore, the crapdanza flywheels are notorious for terrible imbalance out of the box because they don't spend the extra effort in making a perfect product but instead just rush to sell the s***... at least the factory flywheels only need a couple of grams of balancing... the fidanza can take as much as 20 grams to do that in some cases!
