FS: Miscellaneous Items
Adjustable Cam Gears Brand new 160.00
Polished Aluminum Catch cans Oil, Coolant, Power Steering
all for 120 (will throw in extra coolant can)Not willing to Sell seperate as of yet. Descriptions in Post #3
Oil Filter Sandwhich Plate New SOLD
Greddy Oil Sandwhich Plate New SOLD
Lightweight Power Steering pulley Revised new SOLD(will include new old style) made by Medieval
Oil Cooler Kit Brand new 150.00
Custom Battery Tie Down (Anoized Blue) SOLD
Stock Driver's Door Switch w/ plug and wire SOLD
Stock Hazzard switch w/ plug and wire SOLD
Stock Radiator Grommets SOLD
Stock Blank Plates X 2 Make an offer
Tuner Lugs (21 total) w/ Key Brand New SOLD
All Prices are shipped prices to Lower US 48 ONLY
IF interested in Anything please PM me with item description in Subject Title.
Also Please do not clutter the Thread. Thanks for looking
mazdaspeed41 I sent you a PM, did you get it?!
Did you ever have either of the sandwich plates mounted on a Mazda 2.0 engine? Cuz I tried to mount one that looks like the blue one and the threaded shaft coming off the block is so long that it bottomed out in the nut that holds on the plate before the plate was tight against the block. It was supposed to be the right one for the Mazda 2.0 but it didn't work.
no i never had it mounted but i purchased 2 nuts that hold down the MSP oil cooler to jam them together the remove the oil filter nipple and cut it down about an 1"..
Sorry... I haven't been awake too long.... Are you saying you cut an inch off the stock shaft that the oil filter threads on to? If so, how did you get it off to cut it, cus it would be impossible to get at it where it sits.
wakey wakey... i purchased 2 nuts to lock down the stock MSP oil cooler ,to jam them together then removed the nipple (threaded shaft the oil filter attaches to) then cut it down about an 1"
How did you remove it? Does it just unscrew?
Ohhh... Are you saying you put two nuts on the shaft so you had something to get the wrench on so you could unscrew it?
Mazdaspeed Oil cap MSD 30.00
25 shipped?
