Super Low Idle ?
I have just finished rebuilding the motor, the car runs great but when I push in the clutch the idle drops really fast and sometimes it drops so fast the car just cuts off, Trying to see if anyone knows how to fix that?
there should be an idle screw somewhere... look at the how to section and use the search button
Had the same problem years back. There is a Idle screw on the throttle body that will adjust the speed at idle and solve that issue. I turned it and got it to idle at 750 and if will bog but not shut off or hesitate.
