Which coolant to use?
too late
and too late
you already ****** your s*** up... you mixed the coolant and since it's contaminated, you will NEVER get it out save for replacing every component and hot tanking the engine block
so while you may never see any problems out of this, keep in mind that your coolant life has now been reduced
You can't be serious??
you'd be surprise just how little of a different coolant can totally contaminate a system
for example, a retard drains a late model toyota camry's radiator and "flush" it (hell you don't even need to do that on toyotas as its engine blocks typically have a separate drain plug)... the toyota takes the special pink coolant... he puts in regular green s***... there's still a tiny bit pink s*** inside...
result: the coolant turns into a glob of s***
but since what you did doesn't "hurt" the FL22, it really does reduce its life
Isn't coolant a misnomer as the temperatures run cooler with straight water. Is it not actually anti freeze?
When i bought my coolant, i did it from a regular parts store but i made sure that it said for "aluminum engines" on the bottle. If you don't have the FL22 sticker, that should do just fine.
