Simota CAI help please
SpeedToBleed
02 P5
So I just installed my Simota CAI, it was used purchased here.
Now I'm getting a check engine light, is this normal and is there an easy fix?
I used the stop MAF (I think it's called) where they wire harness plugs in. But there is one extra harness that has nowhere to plug into, maybe that's the problem. Any help would be great, thank you!!
Ok I found how to hook up that other harness but still have the check engine light. Maybe just need to reset the computer? How do I do that?
check your connections again...and clamps. i believe you disconnect the battery cable and press the brake pedal for like 30 seconds or something like that. im sure someone will chime in with the exact process.
dude do you have the instructions for your simota pm me if you do wife wants to install and im in iraq not letting her try without instructions lol
Got pics? Would help...
And to reset the ecu, just pull the ecu fuse in the main fuse box.
lata this evening i'll take some pics and send you a detailed msg of how i did it....no instructions were included
right after i sent that msg i realized my car is in the shop....might get it back tomorrow who knows
