The MSP has a very weak block, you can search over countless blown motor threads and regular protege thread. The stock turbo is more than enough to blow the engine. The ECU tuning is very important to not blowing the engine. Get a high flow mid pipe and a WGA to start out with, I think those two parts are the leading cause to blow the engine.
I wouldn't recommend a boost controler as one of the first mods for an MSP.
+1. I got two Boost controllers and i refuse to put them in until its forged.
if you really dont have enough self control then (eek2)
definitely get the exhaust and front mount, they will transform the car. for now, i wouldnt recommend going over the boost its set at (8 psi).
look into an awr front motor mount (reduce wheel hop and helps save the lsd) and look into shifter bushings (kartboy, they may not make them anymore or TWM), transforms the gear box.
vibrant exhaust
shifter bushings
custom front mount intercooler (if you have the know how)
You can not run just the front AWR mount and not the rear. i did this for about a year and i had a klunk that sounded like my rear motor mount was bad, well when i went into change the rear because it was finally getting on my nerves i started looking at the motor mount was fine (i put it off so long because it was a b**** to change) but i started looking and the AWR fronnt mount with out the rear will change the pitch of the motor and cause it to hit on the cross bar that runs long ways under the motor (front to rear.) i know this because it actually left a little wear spot on my tranny and my cross bar. but all in all you CAN do it but it will rub.
