How long do the BC coilovers take to install and are they very difficult to do? Could I do them with just 1-2 friends because I just got quoted by a shop they would charge me $200 to install which I would rather just keep in my pocket if it wasn't too difficult. Also, do I need any special tools besides the springs compressors I could borrow from autozone?
The BC's don't require you to cannibalize the stock suspension. Unbolt the stock pieces and bolt in the BC stuff. Just be sure to adjust the rear shock length to match the rear spring height and you will be golden. I wrote a short writeup when I installed mine but it's on the other forums and it won't let me link it here.
If this isn't low enough for you, you have problems.
What do you mean by this? Like how do you know when they match?
That is low enough for me... I love the way it sitz... What u runnin' 4 ur suspension...? (cool)
Are those RX-8 rims painted matte black?
im taking the rear collars out this weekend and lowering the fronts to match before HIN on the 25th. Ill post some pics next week, its gonna be close w/ the +35s on there (boom01)
I'm anxious to see how it turns out. I wanna lower the rear of mine some more but I haven't rolled the fenders yet. I am really just worried about the paint cracking and then not being able to match the pearl if I were to have it repainted. As it sits now the rear does not rub at all.
Yes they are RX8 wheels painted matte black.
Rear preload is set pretty specifically. You have to unbolt both the spring perch and lower shock mount. Once everything is unbolted and loose you position the spring collar at your desired height and assemble the collar/spring/donut in the spring perches. Using a jack you compress the spring to the point where both the top and bottom are in contact with the upper and lower perch. While doing this grab the spring and try and wiggle it around. Keep compressing the spring by using the jack until the point where the spring does not move vertically or horizontally. Basically you are trying to bring the spring to max rebound without being loose. (1)
Once you are there throw in the bolt that attaches the lower spring perch to the knuckle.(2) Now you raise or lower the shock mount to line up with the mounts on the knuckle. Once you get the shock mount and knuckle mount lined up, throw in the other bolt and tighten her up.
Loosen the set nut on the shock body. By hand turn the shock body clockwise, which will shorten the shock. Continue this until you begin to feel some resistance.(3) As you are turning it, more compression is applied to the spring. The resistance you feel is the proper preload on the spring. For me it was about 10 turns. The theory behind matching the height of the shock to the level established by the spring at max rebound is that in driving situations where max rebound is achieved you dont want to limit the available shock travel by having it too short. The same applies to compression. If its too short you will just hit the bump stops
Before
After - I’m too high
My Front setup
Out of the box
Wastegate13’s setup
The problem when installing the front was that there was no point of reference to set the height to. So we set them to the stock struts and installed. I obviously have mine set too high.
