bobthebowhunter
Do I have to get a new head unit to run amps or can you run one off of the stock non bose system?
Just hook up the remote turn on wire from the amp to either a switch (which I chose not to because if you accidently leave it on there goes your battery), or pop out one of the fuses under the glove box for an accessory that is only on with the key in the on position such as the cigarette lighter (that's what I used) and wrap the wire around it (of course after you stripped off 1/4" or so) then put the fuse back in with the wire around it.
finding a power source for the remote shouldn't be a problem. I was wondering if the stock head unit has RCA out puts.
So explain LOC. Is that basicly what I run my RCA cables from?
