Yummy!
Nice color!
That car is clean...
I sure wish I could find one in California. (naughty)
which mazda was your favorite to own
Yummy!
Nice color!
Insane Pictures like usual Antonie .. must be a damn blast to live in a country like Japan, thats my dream right there, to visit Tokyo or the best places of Japan someday. Atleast me i love their culture, food, Technology ive never being in Japan before but i sure would love to live there some day..
Nice shots bro. I've got to get me one of those hoodies someday.
I have the exact same strut brace in mine, except mine is white. Does yours rub on the hood lining? I know mine does because the white paint shows everything. (pissed)
Just remove the hood lining then. I always remove mine in my cars. Just another item that keeps heat trapped in your engine bay allowing air and fluids to become heat soaked. That may be good in the winter, but not the rest of the year.
Brake pads.......
Fr = BA-323 (V6 version)
Rr = HC-929 (V6 version)
Fuel filter = DB-121 (1300cc EFI version)
Thats what I use here in Oz as they are the same parts.
Air filters are unique so cant helpat this stage
REgards
I know that Cosmo from somewhere..............(lol2)
Paint code = D2
VIN = JCES-100190
Production date = 31-JAN-95
REgards
Strut bar is GORGEOUS!
And you KNOW its well made too.
Thanks Antoine,
the 2 Cosmo's are in stock factory condition and we have no plans to modified the cars, just like our other Mazda's,
the link to the website is www.everyoneweb.com/mazda
Best Regards, Erwin and Hans
( Hans is my son and he drives the 13B Cosmo)
Thanks DMRH,
I had already some information about brake pads and fuel filter from http://eunos.com.au/cosmo/parts.html
it's very difficult to find the original part number for the air filter, and don't know if it's used in other Mazda models,
Best regards, Erwin
What he said!!!
Also, 190*F oil temp seems awfully low to me. I'm used to it taking longer than water to come up to FOT, but when it does, it's usually 20-30*F higher than water temp??? Why oil temp gauges usually read to 300*f and water temp to no more than 250*f.
Also, 180-190* is low for water temp too?
lol @ Bonneville being in UTHA, USA.
As long as your oil and water temps are ok, then I wouldn't worry about the tranny, unless thats known as the weak spot for the 20b (not much of a rotorhead)
If you're really that concerned over the temps your tranny is reaching you could invest in a bigger/better auto tranny cooler. That will probably help a lot.
What he said!!!
after a long drive in the middle of the summer my scangauge tells me my water temp is 190 in the speed6, so thats a normal range.
It seems the 20B is most "comfortable" at highway speeds in terms of opertaing temps.
During what month/season did you see those temps?
In my case...During the summer...I recall seeing a temp range of 88c/190f~105c/221f for water and 95c/203f~110c/230f (113c/235f peak during heavy traffic last August) for oil.
Apsolutely agreed.
My point was that every engine likes to be driven at constant rpm on an open road... After that it depens of the engine (size,power,transmission...bla bla bla) if that speed is gonna be 50kmh or 150kmh![]()
To be honest, and as much as I want a working gauge in my 3, I haven't had an oil temp gauge in a while. But in my Volvos (an 1800S Coupe w/factory gauge and a highly modded 144S w/an AM) and Civic 1500GX (AM gauge, mildly modded) 230-240*f was not unusual for oil once fully up to operating temps no matter what the season.
Actually the 4AT tranny is easily overstressed & prone to failure if too much power is pumped through it. Typically from 400KW I have seen them failing but thats all in big-single turbo territory.
The oil cooler can capture the crud from the transmission as the JATCO unit lacks a filter. The cooler requires a reverse flush to clean it out becuase if clogged up, the tranny overheats & fails.
Always use the best synthetic trans oil available to ensure longevity & change it every 30,000km - 40,000km
REgards
