Like I have said Previously Mr. Lawyer.
..But how could you argue that the upgraded Turbo did not cause the Catastrophic failure of an engine.(now remember..this is an Example only)
And if you, as a lawyer, could get this persons "said" engine warrantied after it is shown that a Mod was placed on it that added stress to the OEM Engine over its designed parameters....Then you sir are the Same as the Owner of the Car.
A crook looking for someone else to pay.
Thats all.
You still fail to understand my friend. In your example, under MM the consumer does not have to prove that the turbo DID NOT cause the failure, the dealer has to prove that the turbo DID cause the failure. That's a huge difference. But, if the dealer can in fact PROVE that the after market turbo caused stress exceeding the OEM engine designed parameters, you are correct that the dealer would likely win. There lies the strength of the consumer's case...it is very difficult for the dealer to meet such a burden of proof. And why would it be crooked to make the dealer live up to its warranty and/or the law? Is it crooked for you to make your mortgage company to live up to the terms of your mortgage...or for the police to require you to live up to the terms of the law against theft. If you do not like the MM law, lobby Congress to change it. Until then, manufacturers of warrantied consumer products will need to comply with pro-consumer laws such MM. Using your logic, or lack thereof, the criminal defendant would have to prove his innocence rather than the state having to prove his guilt.
