Bloodflawz
A few weeks ago I got a new EBC and and it started overboosting and as I was going uphill started hearing this loud knocking sound comming from the engine, and I have some strong vibration comming from the clutch pedal when I depress it.
Its NOT rod knock, I know because I let the car run and removed each spark plug on at a time and the knocking didn't go away. After that I took off the valve cover and noticed the timing chain was pretty loose. I was able to lift it up about 1/2" and also slightly move it from side to side. If thats the prob, how would a loose timing chain cause the clutch pedal to vibrate?
What all would cause the vibration in the clutch and loud knocking? Please help me out guys, I have over 50k miles so the warranty is out of the question.
Thanks
Thanks
