Pics from my 1st AutoX... Massive bandwith required!
dam that sucks lol. Do they do the classed in a specific order?? and if they did. just say rob went before me could i ride with him if he allowed me too??
Yeah, they decide the class run groups at the beginning of the day. Only problem with trying to ride with someone else is that if you're not co-driving the same car, you probably won't have an opportunity to ride. When you're not running, you're working the course.
that stinks, but o well, just sucks its a year away for AutoX to pick up again lol.
April 19th is our first event. May 2nd is a novice school.
A preliminary schedule...
April 19 PE #1
May 2 Novice School
May 3 PE #2
May 17 PE #3
June 7 PE #4
June 20 PE #5
June 21 Car Show/Cookout
July 4 Challenge Event
July 5 PE #6
July 19 PE #7
Aug 2 SCCA Challenge
Aug 16 PE #8
Sept 5 Advanced School
Sept 6 PE #9
Sept 20 PE #10
Oct 4 PE #11
Oct 18 PE #12
I did not go, and I wish I did. My car was broken at the time. They go over all the basics and some tips...then you run the course a bunch with a passenger giving tips. Fez (a C6C'er) went last year and said he had about 10 or 11 runs at the course. He did say that it was very helpful. I will be going this year.
ok cool then ill def. look into doing that. now will the coarse be the same all season, i know i was reading that they have one coarse in the morning and then a different one in the evening. Do they use the same coarse setup all year or is it different for every event.
and btw i did not change anything on your post i hit edit instead of quote lol
Hahaha, no worries.
The course is different every event. The dual course setup is a forward run in the morning, then a reverse in the afternoon. Sometimes they'll change it up a little, such as adding or removing a turn / slalom section. We also have a few different venues that we run at, so the courses will be much different for that too.
Hahaha, no worries.
so how many runs do you get per course if you are doing a day with 2 courses
The RESULTS are in!
Guess it wasn't too bad since I beat a C5 Corvette :P
I'm really looking forward to going again next year. The NHSCC was x10 better than the low key run at BeaveRun.
Anyway, here is a pic:
its only your 2nd time doing it, theres alot to learn haha.
So did you hit 2nd gear at NH
I need to get some real ones.
Masking tape isn't going to cut it...:P
On racepa, someone suggested getting magnetic sheets from the craft store and making your own. I'm going to check there later today...
