B16RacerN2NR
- 2006 Mazda 5
Ok, so after getting the run around from Jiffy Lube and Ford (my local Mazda dealer moved a half hour away a few months ago) I decided to do the drain and fill on my transmission myself. I went to them because I was going to pay for the complete fluid exchange but they suck so I had to take matters into my own hands
I used Castrol Mercon V and Slick 50 ATF Treatment. My step dad has been using it for a few years in my parents Murano and he likes it a lot so I figure since i'm not going to be able to get the fluid out the torque converter, i'll try the Slick 50 stuff since it 'claims' to restore some viscosity to the old fluid.
I'd say about 3 quarts or so drained out. The milk jug I drained the fluid into was almost 3/4 full and I spilled about 1/4 quart to 1/2 quart (bang)(bang)(bang)
The Slick 50 came in a 15 ounce (just 1 ounce shy of half a quart) bottle so I filled the transmission with that and 2 and 1/2 quarts of Castrol ATF.
I drove for a bit and holy hell does the transmission shift smoother
However, I did notice that there is a 'slight' delay between gear shifts. The indictor will show the next number gear and then it'll shift. The delay isn't long though. No longer than half a second, if even that long. The engine doesn't 'rev up' between the transmission shifting gears so that's a good sign. It's like you see the gear indicator go to the next gear and it doesn't shift insync with the the indicator, it shifts right after the number changes on the indicator.
So my question is, am I mistaking this 'slight delay' in the transmission being much smoother now? Or do you think i'm still a little low on fluid?
I couldn't really sit there and check the level because my girlfriend needed the car to go to work and the Slick 50 stuff is sorta thick so it was still in the dipstick tube and would ruin the reading on the dip stick when I pulled it out. I let her take it to work because I know for a fact i'm not too low on fluid to where I should worry about driving the car.
