2016~2023 CX-9 Transmission Fluid Temperature
I’m planning on changing my ATF and I can’t seem to find the transmission fluid temperature on my obd2 bluetooth elm327. I’m using “car scanner” app on android. I tried inputting one of the custom PIDs that was on a shared spreadsheet here to no avail. Hoping to get an assistance. Thank you
UPDATE: got a new obd2 bluetooth veepeak and atf temp showed up
New obd2 bluetooth worked lol
Happy to hear that! Hopefully the ATF drain and fill goes well.
For the record, before I found out about this app, I had planned to use a non-contact infrared thermometer. I figured I might find other uses for the tool around the house compared to a thermometer with a wired probe. Glad I didn't have to buy anything extra lol
Upvote 0
I did the infrared thermometer trick with my older c230 it was fine I guess 🤣. Drain in fill went well, only drained about 4qts, will do it again on next oil change. I also did coolant drain and fill, transfer case, rear diff and oil change. Good for the next 7 years or until I change my brakes!
Upvote 0
