Oil in my CC now...
SharkDiver
Speed3
Hey all,
Ive had my oil CC on for about 4 weeks now and never got a drop of oil in it.I installed my DP about a week ago and now Im getting oil in it daily.How does the DP cause this to happen?
Do you blow smoke with the txs dp, i blew smoke so bad i had to put the stock pipe back in.
thought id post this to help people out as recently wev had quite a few people having problems with bios
all the beep codes are different depending of who makes the bios , but here are some of the more common ones
What is a BIOS Beep Code?
When you power on a computer the BIOS immediately takes control of the computer and performs the P.O.S.T (Power On Self Test). At the end of the POST the computer will play an audible 'BEEP' through either the PC's internal speaker of through speakers attached to the sound card (if you have a built-in sound chip). If the POST completed successfully without detecting any problems with then system will play a single short beep to let you know the test is complete and the computer will continue to startup and load the operating system.
If during the POST the BIOS detects a problem it will normally display a visual error message on the monitor explaining what the problem is. However, if a problem is detected before the BIOS initializes the video card, or a video card is not present or not detected then the BIOS will play several 'BEEPS' through the speaker to let you know there is a problem. Depending on the type of the BIOS you have the BIOS may play beeps in a specific pattern to indicate what the problem is, or play the same beep a number of times indicating the problem. It is very important that you pay close attention to the number and/or pattern of the beeps your computer plays on startup.
Below is a table of the most common AMI, Phoenix and Award BIOS beep codes.
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video cardthought id post this to help people out as recently wev had quite a few people having problems with bios
What CC did you decide to go with? i have just placed an order for a Saikou Michi CC.
Also did you catch can stop your smoke if it was smoking?
I havent had any smoke yet..i just have a ebay CC that works good so far.Im hoping the can will keep me from smoking and now I can see if I didnt have the cc im sure it would be smoking with all this oil going into the intake mani..
here is the CC I have and for the price its pretty damn nice..
http://cgi.ebay.com/ebaymotors/AMK-...hash=item260264257468&_trksid=p3286.m14.l1318
some tanks take a little while to fill up enought to start draining beacuse the drain is not at the bottom of the can.
Its really that bad that your getting oil in it daily? And you use the TurboXS DP?
So basically, this proves the stock PCV valve sucks, right?
Thats what it HAS to be.. I mean the car smokes regaurdless but we don't see it because of our cats.. And i do agree that changing the exaust to make it more free flowing and opening it up with make the problem worse but it doesnt look liek there is a way around it. Its hit or miss really like people have been saying.
Ethier you have a turbo thats okay ora turbo thats doing it already but I think ideffinatlly the turbo seals will go. Im about to purchase my Oil CC and have still to install mt CP-E full TBE. Im ready for the peoblem and if it givre me that much problems F*** it.. Im buying a bolt-on.(cheers)
Don't mean to threadjack, but has anyone tried krank vents (with or without cc) or made their own? I have heard that they do wonders......
Downpipe = Smoke ?
Okay, FNG here so as I read up, search and read up some more on various forums, I'm seeing something that has me wondering.
Is adding a nice down pipe causing the smoke issues or is it the turbo on those particular cars?
What's the deal....to downpipe or not to downpipe. Is adding a catch can just covering up an issue?
Why have the makers of the DP's addressed this? Is it there issue?
It is definitely coming from blown/bad seals on the stock turbos.
What is causing is is related to downpipes/catless exhaust systems, and our turbos simply cannot keep up with the amount of flow. Stock K04s suck, and Mazda knows this and is warrantying them from my readings.
But make sure your intake/exhaust system is stock before going to the dealer.
That's what I figured. Is this the same KO4's used on the GTI VW's in Europe? I believe here they use KO3's but again, not sure on either. I have a lot of VW buds here in Columbus who are turbo junkies and they will surely know.
I called the dealer I'm picking the car up at today too. They do a lot of MS Aftermarket and are mod-friendly...as can be. They are also a Subaru dealer so that's likely why too.
The rep I know well is checking on the MS Intake, Short-Shifter and what Exhaust stuff they have which will net a gain and be covered. I hear the techs there in the shop are awesome and one has a decked out MS3 which is there today, so I'll get to see it.
pdqgp, you talking about Byers? I just got mine up there two weeks ago at mazda direct. Looking for a good dealership close, I'm in cincy.
(no threadjack intended, PM me if you wish)
Yep. Picked mine up today. Pics soon :)
Well I have about 600 miles on my car since the DP install and no smoke yet..I will say that if I didnt have a CC it would be smoking because all the oil im getting in the can would be going into my intake and then burning and causing smoke.Im also running 10w30 PP motor oil so that helps.
