Darksun280
- MS3
I don't think you know what a boost spike is. It's *bad*. You don't want it to happen, period.
I think what you're trying to talk about is call boost taper. The need to gradually drop off boost at high rpm. Something like 13psi@3000 rpm during spool up, 17psi@4500 tapering to 12psi at redline is normal for a turbo car. Something like 13psi@3000, then 22psi@3250, then back to 14.5psi@4000 is a spike and will ruin your motor while getting on the freeway some cool evening.
Without extensive mods and tuning (and a much bigger turbo), no one should be trying to hold 20psi to redline... way too much hot air coming off that small turbo at that sort of flow and boost.
hmmm I call what you call a spike, creep but yeah what im talking about is what you call taper.
