Quote:
Originally Posted by cityracer
so are you blocking off or capping the oil pumps original bypass valve as well? Is this the reason why we would need an external bypass valve system?
Quote:
Originally Posted by MP3racer
.....The main reason we have found for the degredation of oil pressure over time with consistent hard use of the motor is due to the factory bypass regulator causing cavitation inside the pump.
What we have done on our race motors is render this inoperative and replace it with a bypass valve externally. This external bypass valve is adjustable as well.
Thanks for answering this question Crazee D!! I think you guys have the idea!!(thumb)
