Joe you keep mentioning warranty concerns for not doing other mods... Quick question... Did you wire the neons into your stock wiring harness for power?? Or directly to the battery?? Either way if the neons cause a power spike and fry your stock wiring/accessories warranty will not cover it. If the neons cause a excessive drain on the battery its not covered under warranty.So in effect your neon mod can affect your warranty...
If your that concerned about warranty then 0 mods for the warranty period is your best bet...
