Trouble but no clue wats goin on...
nkymsp
03 black mica msp
So i bought my MSP last monday everything has been great with it no probs watsover... until today... it will only build 4or5 lbs of boost and will hold steady at that but wont even make the turkey it just kinda lets all the boost out at once... not only that when i rev it to like 3000 rpm and let it drop back down to idle it almost dies and then levels back out... but while driving if i am goin and just push in the clutch and hold it there like stoppin at a light or somthin it just all out dies... i found a vaccum hose cracked and replaced it but its still doin the same thing and its all out of nowhere... somebody help me please!!!
blow into the vacuum line that goes to the wastegate, if you can blow in then the WG is the problem, let me know.
sounds like you have more than one problem, if you are loosing boost most likely its a vac leak somwhere... hard to find, since you seem to know what your boosting you should have a boost/vac gauge, what is your vac at idle?
for your car dieing when you put the clutch in/reving its probably the EGR valve getting stuck...there is a how-to to fix it in the how-to section...its not too hard to DIY just a PITA to get to
so ya my vac and boost seem to be fine at idle but i think the bpv might be bad b/c it doesnt even turkey anymore it jus like sneezes... but im pretty sure the egr should fix it... im gonna try to clean it and i hope to god that fixes it b/c its pissin me off lol... thanks for the help ill let u all know if i can get it fixed...
so i took the egr off and cleaned it the best i could wit brake cleaner and still didnt fix the problem... if i keep the heat or a/c on full blast it stops the problem... is there ne way it could be the throttle positioning sensor goin bad? if not wat else could i try? i need help here ppl so give me ideas... thanx
did you check the Wastegate?
not yet but i dont c y that would cause the idleing problem... im not exactly new to the turbo but im slightly undereducated about it... and this is my first turbod vehicle so im tryin to do stuff on my own to learn and get aquainted
i will check the wastegate and c if that is bad or somthing... just none of this makes sense to me right now lol
we say the wastegate because its a common problem and it does cause tons of problems for us MSP owners...is its not that it could be a dirty or bad MAP causing the airflow to be misread by the ECU
one of my buddies mentioned that it could be a throttle positioning sensor?
albeit I am not a mechanic, but I do know my way around the FS-DE (to a certain extent) and the common problems with the MSP, I don't think I have ever heard of a throttle positioning sensor on this car....(uhm)
like I said in the post above, I would check the WGA (just because you never know) and clean your MAF to see if it helps
don't clean your MAF with break cleaner, clean it with rubbing alcohol and make sure it completely dries
Yea, i got the same problem as well and i cleaned my EGR twice in a row. can the EGR valve itself go bad? i took mine all apart and theres a little piece that screws into the middle of the EGR internally. it soesnt seem to seat tight when screwed in all the way and the threads that it screws into are plastic, possibly stripped for some reason. So i might get a new EGR valve somewhere....im going to check the wastegate first though. Can a EGR blockoff plate be installed?
I had a similar problems when my bpv got disconnected. I think it just a vacuum leak...do you have the stock ic pipes? If so...check around the bpv. It's as simple as that but takes abit of time to locate. Goodluck!
ya i took the egr off twice and tryed it and im still gettin the same thing... not only that but now im getting a violent jerking when i go to get on it. idk im stressed to the max right now... i loved the car for the first 2 weeks now im starting to ****** hate it lol
