Dyno'd Yesterday
Rican219
MazdaSpeed 6
  • 2-18-08 Dyno Rican219.pdf
I guess I'm a little confused. So you Dyno'd to see what your numbers are without the new turbo and tune...am I correct?
Sooooo.....this is your baseline before you put a bigger turbo and tune?
Make sure you take that atp boost cut defender off when you tune or you'll be the next zoom zoom boom member.
Nice run.
Your BOV sounds amazing. Why does it sound do good besides the VTA? Did the new intake/FMIC do something to get that sound?
Yes I want to see what kind of an improvement I will have.
And this shows me what my mods have gotton me to.
LOLZ Yes I don't want to join that club if I can help it
Nice run.
Yes that corksport FMIC did change the way it sounds it makes more of a flutter like the Supras. LOVE IT!!
Run was on 93
Boost Level more then likely was around 17 to 18 PSI I'm not sure because I was not in the car.
68 Degrees
Humidity 25%
corksport states that with their fmic and ram air intake you will see 1-4 psi higher than stock.
I've had the GT30 turbo for 6+ months, I push her hard everyday... never touched the ECU.
Waiting for the CP-E Version 2 for now, then will spring for the best Standalone available, as long as price is worth it.
