Need offset help
Haltech
Banned
07 Mazdaspeed 3 GT
I found some 5ZIGEN's i like. Although they are only 18 X 7.5, im going to go with them. The question i have is, i can go with the 43mm offset or the 48mm offset. Should i go with the 48? Doesnt that give you a larger lip on the outside of the wheel? Thanks
The offset is how many mm away from the center of the wheel (looking at it from the side). The offset could be either positive, negative, or 0. The lower the offset, the bigger the lip. I would get the 48mm. This will allow you to run a wider tire than if you went with the 43mm.
48 is your best bet, it is within 4mm of the stock offset, like it should be. post some pics of them.
Im going with these.. Silver is a difficult color to get the right wheels for. I think these will look good on the car. But, im known to change my decision, yet again.. I wanted a set of Volks SF Winnings, but not for $700 a piece.
