18 x 8.5??
will wheels this size fit??
I might be wrong, but I think there is one guy on the forums with this size and it is very close to not working. I don't think its necessary to go this wide because you can fit 255 on wheels only 8" wide and anything over 235 is a close call.
Read through this thread(headbang)
http://www.mazdas247.com/forum/showthread.php?t=123690439
255's on 8 would be to wide of a tire, 255 would be pushing it on 8.5.
these are the wheels i want..
what size are they, how much do they wiegh?
sorry, my mistake. With 8" wide you can go up to 245 wide and 8.5" you can fit a 255.
My freind put 245s falkin azenas on 8", he wishes he had gone with 235s. His tires sidewall just does not have enough support to make the 10mm diference worth it. This varies though, some tires fit wider than others.
has anybody experimented with S T R E T C H here on these cars?
i know my VW buddies throw 215s on 9" wheels and it looks dope!
if anyone has throw up some pics please because i want some 18x8.5s on a drop
Looks dope huh? Thats way to big a wheel for that tire man. Putting a 215 on a 8.5 is already pushing it.
i had 18x8 45 offset, hp racing wheel 225/45/18 nitto neogen, worked perfectly
ok thanks...maybe they will release a 18 x 8 or even 18 x 7.5 ... what is stock wheel size including offset??
18x7 52.5mm
Low offsets will fit but I still would not go lower than 48. 45 is really pushing it. also for performace I would not go lower tham 8''. The wider rim will give your tires a crisper more responsive contact patch.
18x7 52.5mm
so an 18 x 8 48 offset would be ideal??
