will wheels this size fit??
I might be wrong, but I think there is one guy on the forums with this size and it is very close to not working. I don't think its necessary to go this wide because you can fit 255 on wheels only 8" wide and anything over 235 is a close call.
what size are they, how much do they wiegh?these are the wheels i want..
My freind put 245s falkin azenas on 8", he wishes he had gone with 235s. His tires sidewall just does not have enough support to make the 10mm diference worth it. This varies though, some tires fit wider than others.sorry, my mistake. With 8" wide you can go up to 245 wide and 8.5" you can fit a 255.
they are 18 x 8.5 not sure on weight
Offset?
29 and 45.....would either work?
ok thanks...maybe they will release a 18 x 8 or even 18 x 7.5 ... what is stock wheel size including offset??
18x7 52.5mm
Low offsets will fit but I still would not go lower than 48. 45 is really pushing it. also for performace I would not go lower tham 8''. The wider rim will give your tires a crisper more responsive contact patch.
so an 18 x 8 48 offset would be ideal??
