Those plugs must be pure gold b/c Denso's ITV20 are 10 - 12 $ each.
Keep in mind, these are OEM from MAZDA. Way OVERPRICED!
So you think my issue sounds like a plug problem and not a fuel cut problem? (confused)
Sorry bud but I dont think your blowing out spark. My guess is its the same thing me and laloosh have had problems with many times. Once the the ecu senses the fp losing pressure it does something to the car that feels like spark blow out. Its pulling timing and closing the throttle plate. You need more fuel. Are you running over 22psi? If not its no way spark blow out. They are gapped at. 28-32 from the factory.
Why do you insist that the main cause of this sputtering everyone is experiencing is from loosing fuel pressure??? reason i ask is because while dynoing my car at nearly 18psi it showed no signs of running out of fuel pressure and neither did your dyno as i recall. just curious what makes you believe that more fuel will fix the problem when these cars run pig rich as it is.
your car is not making enough power. what do u have to fool the map clamp, if nothing, ure not holding 18psi. Also this happens when the weather is cold, like 40 and under, the colder it gets the more it happens. sputtering IS the fuel pressure dropping. look up my posts and look at the datalogs ive posted with just i/tbe/15 and 17psi. Maybe youl change your mind.
just so everyone know before they go out and try to gap there plugs. YOU CANT RE-GAP IRIDIUM PLUGS BECAUSE THEY WILL BE DAMAGE, THEY ALL COME PRE GAPPED!! so if your gonna try this you must by copper plugs instead.
top right hand corner, hit advanced search type in my name and serach for fuel pump, you will see it all
or click this lol
http://www.mazdas247.com/forum/showthread.php?t=123689668&highlight=fuel+pump
He has the proper gap from the service manual, all those other number people ar thowing out are wrong.
The reason is because Iridiums crack so damn easy at the littlest form of detonation.
No, the main reason they are bad for boosted applications is because the irdium portion on the electrode with say glowing hot at cleaning temps in between sparks. this can can cause the fuel to ignite before its supposed too under high cylinder pressures from the boost. thats the main reason people upgrade to coppers, to eliminate that issue.
