Got head?
JDM Sam
Banned
Now I need a spare head to drop these into and grind my cams.
1mm oversize black nitrided stainless steel valves, dual valve springs, titanium retainers, new shims and seals.
I'm surprised to see you asking for a head, I'd figure you had one or at least easy access to one. I'll have a spare motor once I get a built one in. Nice to see you people being cool.
I have 2 but 1 is useless b/c its missing cam caps and the other has bent valves and will need new guides and plugs. Did you get your set yet?
I'm in no rush to put these in. I was going to wait till my next timing belt change before I even bother with this.
No I haven't heard from the shop yet. I guess I have to check with them tomorrow. When did it get sent out? Oh and how often are you changing out the timing belt, I would imagine I'd do it only once or twice in the life of my car.
Just replaced the belt earlier this year when I did the bottom end, I'll prob put this off till next Spring. I have a lot of miles to go before I swap the belt again. At least 60k miles.
it is no t useless because its missing caps, but since it is to you how much for it?
