It is very difficult to do. The information from the sensor is a current, based on a precision voltage regulator in the gauge. A gauge designed to connect to a sensor cannot be put in parallel with the factory setup. Your best bet is to weld in a bung and put in another sensor. Or, you can get the factory information out with an OBDII connected gauge.I know the ms3 has it, how can we use it? Has anybody tired to hook up a guage to it? It would make life alot easier/cheaper if all i need is a guage to tune this thing.
it reads lambda i think thats spelled right and you cant really tune off of the dash hawk it too slow of a sampling rate to give full picture my corksport only had enough bungs for all the factory sensors
The DashHawk is TRASH.Does anyone know if the latest Dashhawk Upgrade read AF? Or do you still have to do the math in your head?
Wait for this one,
The NITROD VPM, the only gauge with true performance testing, monitoring and diagnostic capabilities.
Just copied it. But it real.
Ill bug them too hopefully they will get on it. Everyone email em!
Quite sure. I don't know about what 911t has, but our sensor output is a current proportional to the mixture. The current is based on a precision voltage generated in the gauge. If you put a gauge in parallel the current tries to go to both gauges and neither will read correctly. In series will be really strange. Go ahead and try it and see what happens. The worst it can do is blow up either the gauge, the sensor, or the ECU. Easily fixed, just add money. If it works, let us all know exactly how you did it and we will all learn from it.are you sure about this? I know people with 911Ts that just spice into their stock wideband and it works like a charm.
