What speakers to buy for 03 Protege ES
GIJana
2003 Mazda Protege ES
Hi all, I don't know what speakers to buy for my 03 protege ES.
I want to stick with 6x8 (or 5x7) and 6x9 in the back instead of 6.5 cus i don't want to have to do modifications.
My price range is $100-150 per pair.
I don't know what brand to go with which is my big problem, i don't know much about speaker reputation etc.
I originally was going to buy the following:
Kenwood KFC-X680 and KFC-X690
Any thoughts?
Thanks.
P.S. I'm going to get the Kenwood KDC-X491 receiver.
Any thoughts?
Thanks.
Infinity Kappas are nice if you're not using an external amp.
Thanks, Yeah I forgot to mention that I don't plan on putting a sub or external amp in, at least not in the immediate future, so I want some speakers with decent bass.
Check out www.crutchfield.com. Compare speakers in your price range side-by-side and compare frequency response and sensitivity then search the internet for reviews and comparisons. Crutchfield also has very competitive prices and the best customer service you will find in the business (as reported by Consumer Reports and verified with my own experiences).
Thanks...
Actually the best priced place I've found so far is Techtronics.com
Although I'm not sure how much their shipping is to Canada.
OK I've changed my mind based on some things that I've read here... I've decided to just buy some front speakers right now as some people are saying that having rear speakers doesn't necessarily add to SQ...
So my budget is preferably less tan $200 for a pair of front speakers (forget about the HU, I have one picked out)
So for now I'll leave the stock rear speakers in... so what do you suggest for front speakers?
I'm thinking either Pioneer TS-D681R
or
MB Quart DKG 168
or
Infinity Kappa 682.7cf
The Pioneers have the lowest frequency (so the largest range of sound) but does that necessarily matter?
Thanks.
J
I'm a big fan of MB Quart Reference, but you'll need an external amp though...but you won't be sorry if you use one (amp).
Would you mind explaining to me the use of using an Amp for speakers... I was assuming if I bought a new HU I wouldn't necessarily need an external amp.
I was planning on buying the Kenwood KDC-X491
and this is what it says about it:
The unit's Mos-Fet amplifier is rated at 22 watts x 4 channel RMS and 50 watts x 4 channel peak.
3-Sets of 4V Preamp Outputs: The KDC-X491 features front, rear and subwoofer 4V preamp outputs. The Subwoofer preamp output can be turned On or Off and adjusted independently. The front and rear speaker preamp outputs are balance and fade adjustable. The subwoofer preamp output is non-fading. The front and rear preamp outputs are fixed to the chassis, while the subwoofer output is on 7.5" pigtail lead.
Front and Rear High-Pass Filter:
The KDC-X491 features an independent High-Pass Crossover for the front and rear channels. You can adjust the high-pass crossover from through, 40, 60, 80, 100, 120, 150, or 180, 220Hz. The "Through" selection is a full-range setting. This feature is very helpful when you have smaller-type speakers in the front and larger-type speakers installed in the rear of the vehicle.
Low-Pass Filter: The receiver features a built-in Low Pass Filter control for the preamp-output when the Subwoofer Output is "on". You can select from 50, 60, 80, 100,120Hz or Through. The "Through" setting allows your external amplifier's crossover network to do all the filtering for your subwoofer.
Subwoofer Level: Once you have switched the Subwoofer Output to "on" you can independently control the subwoofer preamp output level from the CD receiver. You select levels between -15 to +15.
Speaker Settings: The Speaker Setting function tailors the System Q Sound Control settings according to the type of speakers in your vehicle. You may select a Speaker Setting of "SP Off" (flat), "SP OEM" (for OEM factory speaker systems), "SP 6x9/6" (for systems with 6" and 6"x9" speakers), or "SP 5/4" (for systems with 4" and 5" speakers).
Note: The Speaker Setting affects the bass, midrange, and treble values of the System Q presets. The speaker setting should be selected first.
System Q Sound Control:
Six EQ curves are preset into memory, allowing you to recall the best preset EQ curve for different types of music. Each preset has its own level settings for bass (100Hz), midrange (1kHz), and treble (10kHz). The 6 preset curves with their respective bass, mid, and treble levels are as follows:
* Rock: Bass +6, Mid +1, Treble +2
* Pops: Bass +3, Mid +2, Treble +6
* Easy: Bass +6, Mid 0, Treble -2
* Top 40: Bass +3, Mid +1, Treble +8
* Jazz: Bass +5, Mid +2, Treble +2
* Natural (Flat): Bass 0, Mid 0, Treble 0
Note: The above values reflect the System Q settings when the Speaker Setting function is turned off. When the Speaker Settings are selected, the System Q level settings are different.
Bass/Treble/Mid Control: The KDC-X491 features independent Bass, Treble and Midrange control. You can adjust each one from -8 to +8db.
Detail Audio Control:
The Detail Audio Control allows you to adjust the following settings for the Bass, Treble and Mid levels.
* Bass Level:
o Frequency: 40/50/60/70/80/100/120/150 Hz
o Q-Factor: 1.00/1.25/1.50/2.00
o Bass Extend: On/Off (when this feature is set to "On", the low frequency response is extended by 20%)
* Mid Level:
o Frequency: 0.5/1.0/1.5/2.0 kHz
o Q-Factor: 1.0/2.0
* Treble Level:
o Frequency: 1.0/12.5/15.0/17.5 kHz
Loudness: The Loudness feature compensates for low and high tones during low volume. You can turn this feature either on or off. Only the low tone is compensated for when the tuner is selected as a source.
Well, it gives you more flexibility. For instance, the mb quart reference require an external amp to "turn them on" because they need more power than the head unit can give. Also the sound (to me) is much clearer. Besides, you would rather have too much power than not enough. And I'm not even gonna get into subs!!!
The problem is the word "need".
No, you do not need an amp for any speak. Much like you don't "need" a new head unit for new speakers.
However to get the performance out of the speakers you are buying you may want one.
Anything other then common $100 or less drop in coaxle replacement speakes...I advise you to get an external amplifier. Even with basic replacement speakers or factory speakers, the external amp can make a very noticable difference. The reality is that aftermarket head units do not have much more power then facotry ones, these days, sometimes they have less. Also, aftermarket speakers will not be as loud in the lower end of the sound range as the factory speakers as they are built out of a heavier, sturdier material. Also they are designed to take more power...so it takes more to move them.
There is no right way here. There is just the quality you expect and what your willing to pay for.
I would not take a Kenwood deck if it was free, I have seen way to many break. Pioneer, Eclipse, and Alpine are my Go-To's. Been leaning toward Pioneer which is what I have.
