WillKill MP5 Build
BlkWidow
GT28RS+MP5= FUN!!!
Contributor
2002.5 Protege5T
The weather is nice, so I wanted to do a photo shot of most of the parts I have to put on the car. Their are still some parts on order, need to order, build, or redo in the next couple of months. That is after i fix the wife car from the hit and run a few weeks back. I am going to be doing updates as it happens.
old set up
Suspension Work to be done
1. ROTA GT3 in BLACK (JUST FOR YOU SANBLASTER1 !!!!!!)(not shown have to pick them up)
2. GT Spec Front strut bar (Installed 04/23/09 but bar to be polished)
3. GT Spec 4-point Ladder Brace (Installed 04/23/09)
4. GT Spec Rear 4-Point Linkage Bars (Installed 02/10/09)
5. GT Spec Trunk Reinforcement Bar (Installed 02/10/09)
6. Front MSP sway Bar
7. AWR Front/Rear Swar Bar Links (Installed Rear 05/016/09)
8. Front Camber Bolts
9. Install Posi Quiet Front Brakes (Installed 09/10/09)
10. Racing Beat Rear Sway Bar (Installed 09/10/09)
New Pads
http://i241.photobucket.com/albums/ff236/boostdmp5/DSCN1603.jpg
4-Point Ladder Bar Installed
  • <!-- BEGIN: Album Thumbnail Element 0 -->
AWR Sway Bar Links
<!-- END: Album Thumbnail Element 0 --><!-- BEGIN: Album Thumbnail Element 1 --><!-- END: Album Thumbnail Element 0 -->
Interior Work to be Done
1. Install WHITE SOX CAPS!!!!!!!!!
2. Install MSP Floor Matts
3. Instll Carbon Fiber Glove Box Panel (Installed 3/10/10)
4. Install Steering Column Gauge Pod (sold)
5. Install Dead Pedal
C/F Cover Installed
Exterior Work to be Done
1. Install New Splash Guards (Fixed 04/20/09
2. Replace Broke Neon (Replaced 04/24/09)
3. Install TCS Carbon Fiber Mirrors SOLD
4. Install MazdaSpeed License Plate Cover (05/16/09)
5. Install New Front Plate Bracket(Installed 04/23/09)
6. Install LED Rear Signal Bulbs(need to orde more)
7. Install JDM Rear taillights (Installed 2/14/11)
8. Install Isport C/F Rain guards (Installed 12/24/10)
9. Install Isport C/F Rear Spoiler Lip (Not mounted Just what It would look like)
10. Install Isport C/F ADP (This is for show)
Front Plate Installed
Old Splash Guards
New Splash Guards Installed
JDM Taillights
Spoiler Lip not mounted yet
ADP for show
Audio Work to be Done
1. Build 12" Single Speaker Box
2. Rewire Amps
Engine Work to be Done
1. Install MAM Manifold (Installed 02/08/09)
2. Install MAM Down-Pipe(Installed 02/28/09)
3. Install MAM Vaccum Block (Installed 04/24/09)
4. Install GT28RS(Installed 02/028/09)
5. Install Perrin Fuel Rail
6. Install AWR Rear Engine Mount (95 durometer) (Installed 07/15/10)
7. 1.8 Valve Cover(precut for cam gears) (Installed 01/20/10)
8. WRX injectors(SOLD to Deatschwerks)
9. High Flow Fuel Pump
10. MSP ECU (Installed 02/09/10)
11. SSFC(SOLD GOING WITH MICROTECH)
12. J&S & Knock Sensor (Sensor and wire installed 04/25/09) Need to wire in into ECU
13. SLS thermostat housing(installed 02/28/09)
14. MicoTech LT-10s(arrived)
15. Install NEW Deatschwerks 440 Injectors(arrived 4/08/09)
16. Install Weapon R Oil Catch Can (04/23/09 Installed)
17. AWR Oil Pan (Installed)
18. Coolant lines new ones (Installed 05/16/09)
19. 3" Air Filter (Installed 02/01/11 so i can stop hearing you need something)
20. MSP Oil Cooler (Installed 05/15/10)
21. ProSport Oil Pressure, Oil Temp & Coolant Gauges (Installed 05/15/10)
22. CorkSport Radiator (Installed 11/12/10)
23. MFactory LSD (At a shop being installed w/GTX 3rd & 5th gears)
02/08/09 what's missing?
02/08/09 Sealed (alright)
02/08/09 Need to reclock
02/08/09 Manifold and WG mounted
Weapon R Catch Can Installed 4/23/09
MAM Vacuum Block Installed 4/24/09
MSP Oil Cooler w/ProSport Oil Pressure & Temp Sensors 05/15/10
ProSport Temp Sensor
Gauges Installed
Gauges During The Day
Gauges During The Night
CorkSport Radiator
CorkSport Installed w/JDM 1.3 Cap
Trans Out of The Car
MFactory LSD on Drive Shaft
Clutch Master Stage2
<!-- END: Album Thumbnail Element 4 --><!-- BEGIN: Album Thumbnail Element 5 --><!-- END: Album Thumbnail Element 0 --><!-- BEGIN: Album Thumbnail Element 1 -->
Redo Work to be Done
1. Reroute FMIC Piping (All done 04/22/09)
2. Tuning
I have those same TCS mirrors. They look pretty good. Just take your time and get the fittment right on. I have to cut down the mounting perches to bring them closer to the body and window trim.
