will i rub
02pro-es
2002,ES
I just bought a set of gold-line springs for my 02 es. I have 17's with 205/40 tires will i rub? If so how much
most likely not. unless you have a really low offset on your 17s, you should be fine. i am running goldlines and 19s and no rubbing. you will like the drop and ride(2thumbs)
As stated....it will depend on the offset of your wheels....
the recommendation from the expert is....the expert being Rishie,
if they are 17 X 7....you should have a +45 offset...if they are 7.5's then a +48 is recommended. with those offsets you won't rub....if they are less than that....they there is a possiblilty....but you can USUALLY but not always get away with as much as 3 mm less that optimal.
(stash)
I have goldlines on my 2000 with 205/40/17's on 7.5" rota subzero's ..no rubbing yet .. the rota's are a 45 offset
Jon
I have the eibach prokit and 17.5 wheels with a 40 offset and 215/40/17 tires. I rub when i have more then 2 passengers but all I have to do is shave the inside of the fender or roll it up and ill be fine
